Course regarding making for 3d scanned objects
DboeghDboegh Member Posts: 2
Hi Onshape
I'm fairly new to CAD, started some selfpaced courses and are loving it!
I do however look after look for a course for when you have a 3d scanned object, from which I want to a change to/add new parts.
Can anyone point me in the right direction of a course regarding the needed insight for this type of drawing?
Best regards
Daniel
  • larry_wright416larry_wright416 Member Posts: 5
    Did you have any luck with this? I am in the same boat right now.
  • matthew_bohrer774matthew_bohrer774 Member Posts: 3
    I've been thinking about preparing something on this after working on an elaborate example this summer, but in the meantime I can point you to @EvanReese and his amazing work in this area:
    https://www.youtube.com/watch?v=P4n6U9uLxWk&list=WL&index=1&t=1363s&ab_channel=EvanReese
  • EvanReeseEvanReese Member, Mentor Posts: 2,865 PRO
    edited August 2025
    Thanks! I'm sure there is still a lot of room for expertise in this area. Those were are experiments from someone that doesn't really use scans all that often. I'd love to see more case studies of production use.
