How to divide an angle variable by two and use it in dimension
So I have an angle defined as 40deg and I'd like to use half it to constraint a dimension. However onshape tells me this is not a valid expression. May I ask for advice here? Thanks!
#angle is not the same thing as #Angle 😉
Oops. Embarrassing.
