How to divide an angle variable by two and use it in dimension
jeff_pengjeff_peng Member Posts: 6
So I have an angle defined as 40deg and I'd like to use half it to constraint a dimension. However onshape tells me this is not a valid expression. May I ask for advice here? Thanks!
  • jeff_pengjeff_peng Member Posts: 6
    Oops. Embarrassing.
