I am unable to create classes.
gregory_crookendale
Member Posts: 1 EDU
I am unable to create classes. The option is not available when I click on CREATE. Any advice?
I have the same issue….
I take exception to the following…
That does not agree with OnShape Help. It lists Educator Classes under the Educator Subscription.
If your statement is true, then your training documents and your help database are out of date. That is a serious issue.
Someone from PTC needs to address this.
Or.. The onshape help is correct and Neil was correct when he wrote those words in reply to a question on this forum nearly TWO YEARS AGO?
Thanks @Ste_Wilson - yes, the Onshape Educator Plan was introduced in Dec 2023 - @Dr_Richard_Gregory if you cannot see "Classes" under the "Create" dropdown, please create a support ticket.
