Wanted: Sane API that Corresponds to Interface Actions
Why is this not an automatic assumed given?
Why is the norm for writing OnShape code that we are expected to re-implement the features already provided by the app but not provided to the API?
Why can't we construct sketches by describing their constraints, the same way we would in the app?
Why aren't products of code accessible as first-class objects?
It's offensive how silly the API is. Why isn't there a real API that works the intelligent way the app works?
  • AsherAtSignalDesignAsherAtSignalDesign Member Posts: 34 PRO
    And why can't we name sketches? That's so far beyond insane I can't even comprehend it. It undermines all basis for organization.
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    @asher_haig , And why can't we name sketches? : Can you let us know what you tried? You should be able to set the name of the sketch at creation see this example : https://onshape-public.github.io/docs/api-adv/featureaccess/#create-a-sketch-via-querystring or if you want to update the name of a sketch (or any other feature) see this example : https://onshape-public.github.io/docs/api-adv/featureaccess/#update-a-feature
    How can it be done in Featurescript rather than via an external URL call?
    I'm looking for something sane like:
    var sketch = newSketchOnPlane(context, sketch_id, {
        "Name" : "Neck Relief Sketch",
        "sketchPlane" : plane
    sketch.name = "Neck Relief Sketch";
    Also, why doesn't it simply use the already provided "Name" parameter? This seems so basic.
    edited August 2025
    Hi Asher, Currently we do not have the ability to set sketch feature names via FeatureScript. I created an improvement request for this.
  • _anton_anton Member, Onshape Employees Posts: 515 image
    newSketchOnPlane has no "Name" parameter, as far as I know. It *is* a fair point that the Sketch 1, etc. under the feature can't be named; feel free to vote on the improvement request.
    Where do I find the improvement request?
    If you check your support tickets, you should the improvement request we created for you.
