sorting public document search results by likes, copies, links
tom_10
tom_10 Member Posts: 10 ✭✭
public documents are a powerful tool for open source as they allow modification and improvements. when searching for a project sometimes I want to see the leading projects in a field, i.e 3d printers. there used to be the option to sort public document search results by likes, copies, # of links. now it is gone? strangely the option to search ALL public docs by these categories is available. so it is easy to find the utmost popular projects like FarmBot, but very hard to find projects with ~10 likes or copies.  this is silly!! am I missing something?
  • tom_10
    anyone?
  • kguo@onshape.com
    kguo@onshape.com Member Posts: 1 image
    Tom,
    Thanks for the question. Currently, sorting is not available in searching for public documents and other document filters also. Please open an enhancement request, we will prioritize it appropriately.
    Kevin
  • billy2
    edited July 2018
    @kguo@onshape.com
     what does the promotedAt filter do when added to a public search?
    to be specific:
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    @billy2
    I think promotedAt is the default filter for viewing public documents in Onshape (not through the API)
  • billy2
    @mbartlett21 I toggle it on/off when looking at public documents. They appear to be more evolved and I think they have a certain number likes. I'm using the API and toggling it on/off. Not sure what it does.
    I found this post interesting because I too want to see the cool stuff, it's interesting to search by modify date & see what people are building:
  • tom_10
    thanks for the reply! I work at Maker/Fab labs and Onshape is becoming increasingly useful as a tool for open-source, as more projects are sharing onshape project links and not just "dumb" STL/DXF files. I think Onshape should be more forward-looking in this regard and encourage this. for example:
    - addressing the "copy of copy of copy..." issue , making it easier to find the "original" or "source" of a shared project (such as the "derivative" feature on other sites) , this can also be more fair towards open-source project developers , to ensure proper crediting of original designers.
    - making it easier to find and use and share FeatureScript scripts
    keep up the good work!
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,150 PRO
    Great point @tom_10, I'd love to see a solution to the "copy of copy of copy" public document.  The structure is there for this to be used, it just needs to be enabled. However, I am sure there would be various scenarios needing to be considered for this to take place and maybe a few more checkboxes would be needed on public doc but should be doable.
  • tharaldsen_as
    tharaldsen_as Member Posts: 6 ✭
    Hey, is there a reason we still can't sort 7 years later? Before searching one can, but not after..
  • tharaldsen_as
    Bump
