Cutlist only has item number and qty
derek_lastiwkaderek_lastiwka Member Posts: 2
I am trying to make an onshape cutlist with beams. When I create the cutlist the only columns are item number and qty. How do I get length and description to show up?
  • MichaelPascoeMichaelPascoe Member Posts: 2,763 PRO
    edited August 2025
    Please share a link to your document. It sounds like you are trying to use the assembly BOM table instead of the cutlist feature and the cutlist table that is within the part studio.
    If you do want to use the assembly BOM, you can use the Cut list+ feature which lets you name the parts based on their profile, length, and cut measurements, etc..
