connecting lines on different planes
giel_den_hertoggiel_den_hertog Member Posts: 4
hi, i made this sketch of a boat but i cant seem to connect the lines together on different planes so making it in to a part is not working. is there a way to do that after the fact if not how do i do that in the future?
  • glen_dewsburyglen_dewsbury Member Posts: 1,170 PRO
    You can use 3d fit spline from point to point. This will give a line in 3d. If any thing besides the input of 2 vertices are applied it will not be a line.
  • MDesignMDesign Member Posts: 1,154 PRO
    make use of the pierce constraint
  • giel_den_hertoggiel_den_hertog Member Posts: 4
    thanks Il give them a shot
