Frames cut list items too long
Tinus
Member Posts: 6 PRO
Hi,
when using the frames tool using angle steel I get funny results in the cut list when using limit frame ends.
The little extension from the subtraction of the two profiles leaves the cut list pretty much useless.
Is anyone else having trouble with this?
This is why I rarely use the up to part option. Often, you can avoid this by using up to face.
Unfortunately it is not possible to trim to multiple faces for one end. You end up with overlap, but the overall length ends up correct.
You could use the delete face tool on those two rounded area to get a "real" cut. The length in the cutlist is updated with that change.
