How do I pass on "internal" errors to the user?
joshtargojoshtargo Member Posts: 454 EDU
For example, if they try something and it says this in the console, can I capture that error and post it as a reportFeatureWarning?
Also, the documentation is pretty bad for try/throw/catch (for a non programmer). what is the "e" catch (e)? What does throwing "e" do?
    edited September 1
    e is a variable that holds whatever was thrown.
    Generally with throw regenError or similar, it is a map value with a message and some errorEntities.
    I've often used this in something like the below to make sure that errors come through to the user:
    try {
    } catch (err) {
       if (err is map)
          throw err; // it will already present nicely
       else
          throw regenError(toString(err));
  • joshtargojoshtargo Member Posts: 454 EDU
  • Alex_KempenAlex_Kempen Member Posts: 255 EDU
    If you want the error directly, you can also use processSubfeatureStatus with propagateErrorDisplay set to true. This has the added benefit of giving you error bodies/highlighting from standard Onshape features (like a hole feature or a fillet). There is also callSubfeatureAndProcessStatus, which is just a more direct wrapper around processSubfeatureStatus.
    incredible. this is great because the failed polyline or whatever stays visible and red, rather than disappearing. great!!
