Improvements to Onshape - August 29th, 2025
mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 187
edited August 29 in New in Onshape
This update to Onshape delivers groundbreaking improvements to parametric design intent with Query Variables in Part Studios. It also includes highly requested drawing enhancements and a new Notes panel to capture and share design context more clearly.
CAD IMPROVEMENTS
QUERY VARIABLES
The new Query variable tool allows you to create parametrically-defined selections. These selections are available to be used downstream as input selections in virtually all Onshape features. Since they automatically update and rebuild based on design changes to your model, they maintain design intent in ways that previously would not be possible.
https://onshape.wistia.com/medias/1jlegsdgll
Query variables are incredibly powerful, have wide-reaching use cases, and a large depth of functionality. Please be sure to review the Help Documentation for more information.
DERIVED PROPERTIES
When using Derive, there is now a checkbox to include properties from the derived part, and if they are not included, the properties are automatically cleared in the new Part.
DRAWINGS IMPROVEMENTS
TRIM SKETCH
The new Trim tool in Drawings quickly cleans up excess geometry by trimming to intersections or removing entire entities and points.
https://onshape.wistia.com/medias/xqqr9kb9uz
COSMETIC THREAD PROPERTIES
Onshape Drawings now includes controls for cosmetic thread style and appearance. Choose ANSI, ISO, or JIS standards, and adjust color or line thickness to match your templates.
https://onshape.wistia.com/medias/rn8prfq6o8
REVISION TABLE CALLOUT NOTIFICATION
Onshape Drawings now provides a blue notification when revision callouts are hidden. Right-click the revision row and select Show Revision Callouts to unhide them, giving you clear visibility and control.
https://onshape.wistia.com/medias/qxigqf3ohl
DATA MANAGEMENT IMPROVEMENTS
DOCUMENT NOTES
Document Notes bring design context directly into your work. Add text, Markdown, and links inside any document, and see the same notes on the Documents and Search page.  Notes are for the entire Document, and are not version or workspace specific.
https://onshape.wistia.com/medias/8r65qk1n4o
IMPORT IMPROVEMENTS
When importing files in Onshape, you'll now find a more detailed status notification. This shows the specific steps required, and if an error occurs you can more clearly understand where in the process it occurred.
DXF EXPORT WITH WORKSPACE UNITS OPTION
When exporting DWG & DXF files from Part Studios there is now an option to use the workspace units. You can uncheck this option and choose any other units you prefer.
UPDATE WORKSPACE
When Onshape pushes a new release, all documents and workspaces must also be updated. This process is automatically completed in the hours just after the release. In fact, you may have noticed this statement at the bottom of our forum post always accounts for this by including the following statement:
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.
The upgrade process applies only to active workspaces, not older versions or workspaces. In cases like restoring or branching from an older version or worksapce, a manual update option is available in the Document menu when needed.  This option does not replace, nor is it a substitute for automatic document updates - which will still occur as normally scheduled after an Onshape update is released. It is only advised to use this option in the rare scenarios that it is required.
CAM STUDIO IMPROVEMENTS
PROGRESSIVE SELECTION FILTER FOR HOLES
CAM Studio now includes powerful selection tools for machining. Quickly select all blind or through holes, then filter by diameter or depth to set up drilling operations faster.
https://onshape.wistia.com/medias/3hj4r98mk4
NEW MACHINE SUPPORT
New posts available for these machines.
Haas VF-2SSYT vertical mill
Thermwood
CS45 5 x 10 foot router
To have a post included in Onshape CAM Studio, simply file a support request.
PCB STUDIO IMPROVEMENTS
PCB STUDIO TREE
PCB Studio now displays a full feature tree for imported ECAD data. IDF data show boards, components, and keep-in/out areas, while IDX data also include layers, stack-ups, and regions.
https://onshape.wistia.com/medias/jgbb2pnae6
Regards,
Mike LaFleche   @mlaflecheCAD
«1
  • MatthewMatthew OS Professional, Developers, User Group Leader Posts: 27 PRO
    Thank you for the DXF update! I had just logged a support ticket on that recently!! Now if only it did not export two profiles for each hole when using the hole tool on sheet metal, will be submitting a ticket on that shortly
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 206 PRO
    Inb4 @MichaelPascoe starts refactoring all of his query finder based functions. I know I've got a few scripts that I'm going to be redoing from scratch to take advantage of this new feature.
  • eric_pestyeric_pesty Member Posts: 2,318 PRO
    Query variables is huge! This has the potential to change how models are built, especially for highly configurable stuff. Looking forward to trying it out!
    Document notes look very useful, and I've wanted a manual workspace update so many times!
    Definitely a happy Friday before a long weekend!
  • Nick_HolzemNick_Holzem Member Posts: 163 PRO
    edited August 29
    Prayers have been answered! Thank you. 😊Query Variables sounds pretty sweet. Looking forward to exploring that one.
    Still looking for these requests to be filled:
    *Add Internal guide/profiles to boundary surface
    *Fix the Curve/Surface analysis tool to retain selections with final button (drops inputs depending on selections and scenarios)
    *Improve sketch performance while using curvature constrains
    *Sketch blocks
    *Allow configurations to reference releases of parts and their configurations in an assembly
    *G3 sketch constrain, surface end condition, and fillet/face blend option
  • tjonestjones Member Posts: 3 PRO
    Hm.
    RIP sheetMetalUnfold.fs, you'll always live on in my cursed origami tools.
  • MichaelPascoeMichaelPascoe Member Posts: 2,514 PRO
    Woot! 🎉
    "The query finder is dead, long live the query variable!"
    I've never been so happy to deprecate one of my own new features Query Finder 😁
    This is exciting news!
  • Andre_ComellaAndre_Comella Member Posts: 70 PRO
    Between Query Variables and Document Notes, this is my favorite and likely most useful update yet! I'm genuinely thrilled to see these
  • Cary_BettenhausenCary_Bettenhausen Member Posts: 47 PRO
    Hell yes! So much good stuff here, immediately useful.
    Thanks to the Onshape Team for your hard work, you are truly appreciated.
  • S1monS1mon Member Posts: 3,519 PRO
    edited August 29
    For years I've been wanting there to be something with the power of Grasshopper for Rhino, but in Onshape. Query Variables feels like an essential part of a very Onshape approach to this goal.
    This isn't fully thought out, but what if there was a "pattern variable" or some other way of generating a list of inputs for other features? Patterning tools in Onshape are powerful, but having to essentially construct a weird For loop in Onshape with a variable feature like #P=#P+1 always feels a bit convoluted. I'd like to generate a list of dimensions, or dimensionless indices, or U/V vertices etc to drive features. Being able to do some math or calculations within the definition of that pattern variable would be great.
    Curious to see if you've played with the methods discussed here:
    I haven't tried it yet but you might be able to do some more interesting math…
    More what I'm thinking is that instead of - to take a really basic example - patterning an offset plane with a feature pattern, I was to generate a list of offsets, and then feed that into a plane feature.
    This obviously doesn't work yet, but something like:
    In my example above, I would manually generate the list of dimensions, but ideally, we'd have tools like Range, Series, and Sequence (and well beyond that) from Grasshopper:
    https://grasshopperdocs.com/components/grasshoppersets/range.html
    https://grasshopperdocs.com/components/grasshoppersets/series.html
    https://grasshopperdocs.com/components/grasshoppersets/sequence.html
  • aeromorrisonaeromorrison Member Posts: 66 PRO
    Query Variables and Document Notes!! These are all huge enablers.
    Happy to see Workspace Update as well. You don't appreciate this one until you really need it!
    The other updates are all solid as well.
    edited August 29
    Now that I've tried query variables briefly, a few thoughts:
    I'd really like to be able to create a query while I'm in a feature - just like I can create a variable on the fly in other contexts. One difference with @EvanReese 's Selection Fillet is that you can live preview not just the edges, but also the result. Of course with the [Final] button and a fillet feature in place after the query variable, you can simulate this, but it's not quite as immediate. Perhaps this is coming in the future?
    Within FeatureScript I've managed to get sketch points from a sketch as a query without selecting the vertices of other lines in the sketch. I couldn't quickly figure out how to do that in the query variable.
    I hope there are more query variable videos coming in the future. Building queries is really powerful, but it will definitely take some learning.
    I was very happy to be able to do something I've been wanting a lot lately: parametrically pick edges of a sheet metal model to add corner breaks to. I was surprised to see that one of my queries (#inside_corners) didn't work unless I evaluated it on use (or just move it right before the second Corner break).
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 118 PRO
    All good stuff but Query Variables is EPIC!!! It solves a huge issue I wrote like 3 featurescripts to overcome
  • Konst_ShKonst_Sh Member Posts: 65 PRO
    I believe most of these you can archive with my Parameter pattern:
    https://cad.onshape.com/documents/08581b09a233afffddba1401/w/f4d67b2b9675b6e2e9e9f600/e/c5f4954bba4130216c757bdd
  • shawn_crockershawn_crocker Member, OS Professional Posts: 901 PRO
    Query variables is huge! This seems to be a really elegant solution to a cad problem I think most people experience day to day. I can't wait to start implementing this in some of my reusable standard library models.
  • LarkinLarkin Member Posts: 10 PRO
    WOOO NEW STUFF WOOO
    Seriously though, this update is HUGE. TYSM to the amazing team behind this ever-evolving program.
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 260 ✭✭✭
    Besides the Query variables, the Document notes are also awesome. Now you don't necessarily need the Link Tab Utilities app anymore because URLs are recognized in Notes and therefore active (sorry @lougallo ). However... a Link Tab is always visible and therefore indicates a URL, whereas Notes doesn't. As long as you don't press the Note button, you won't see that a note exists. That's why I posted an IR requesting an indicator.
    This is the link to the IR:
    Henk de Vlaam
  • josh_grasby107josh_grasby107 Member Posts: 2
    Impressive additions here, QV and doc notes I love these!
  • Matt_NCMatt_NC Member Posts: 10 PRO
    Query variable are great (I have already found several uses for them!)
    It would be great if they could be used to control appearances too; for example, on labels where you need to change the text, but don't want an embossed/debossed surface
  • Philip_Thomas_PTCPhilip_Thomas_PTC Member Posts: 12 PRO
    @EvanReese - we very nearly did allow the creation of QVs ‘on the fly’. The main reason we didn’t for this release was that a user would not be able to locate where in the tree the QV was defined (if they had reused the QV and later needed to edit its definition) or worse still suppressed or deleted the feature containing the definition. One idea discussed was limiting the scope of use to only the containing feature (a ‘local’ QV if you like). We still might do this but wanted to see how QVs were received first (pretty well by all accounts :))!
