Creating Sheet Metal Object via Feature Script
eca_elioaceca_elioac Member Posts: 17 ✭✭
Hi All,
When I create a sheet Metal object via feature script. In the sheet Metal Context window, It shows "Unknown" instead of the usual "Sheet metal model 1"…
How do we control this behavior in featurescript?
Thanks in advance!!!
  • Caden_ArmstrongCaden_Armstrong Member Posts: 413 PRO
    Sheet metal is pretty difficult to work with in FeatureScript. My recommendation is to not use the underlying sheet metal functionality, but rather to just call the existing sheet metal features with your featurescript. Calling the Onshape written features as sub features is going to produce more consistent results, won't break as easily, and will be faster/easier to develop with.
  • eca_elioaceca_elioac Member Posts: 17 ✭✭
    FeatureScript 2752;
    export import(path : "onshape/std/common.fs", version : "2752.0");
    export import(path : "onshape/std/sheetMetalStart.fs", version : "2752.0");
    annotation { "Feature Type Name" : "Sm Thicken", "Feature Type Description" : "Wrapper for sheetMetalStart (THICKEN)" }
    export const mySmThicken = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
    annotation { "Name" : "Sketch/Face to Thicken", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
    definition.mySketchToThicken is Query;
    var myDef = {
    "process" : SMProcessType.THICKEN,
    "regions" : definition.mySketchToThicken,
    "thickness" : 0.0516 * inch,
    "radius" : 0.1 * inch,
    "bends" : qNothing()
        callSubfeatureAndProcessStatus(id, sheetMetalStart, context, id + 'sMstart', myDef);
    Hi Caden,
    I constructed the script above just as you suggested but I'm still running into the same issue.. I'm getting "Unknown" in the Sheet metal context window instead of the normal "Sheet metal model 1"
  • lanalana Onshape Employees Posts: 761 image
    That piece of UI is specific to the standard sheetMetalStart feature. I don't think you can coax it to work with your feature. Sorry.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 846 PRO
    Just ran into this today. I'm not satisfied with my contexts being labeled as "Unknown" so I'm taking the hard road and duplicating the code from vanilla sheet metal and reapplying it in my feature. Would be cool if there were support for this UI element for custom sheet metal features in the future because I've got a fair number of custom ones I'm developing that have a sheet metal output.
