Mate connector in part does not show in assembly
in General
Hi,
Good day to all.
I have a spring part that I created using in context mode. Then I defined an explicit mate connector on it. The problem is that when I try fastened mate in Assembly studio, the mate connector does not show up. It is not easy to assemble springs as the exis can't be defined easiy. I also cannot show reference geometry(such as curves, surfaces etc.) in asssembly mode. Why is this happening?
Kind Regards
Anirudh Neha
Here is the document link:
https://cad.onshape.com/documents/aa9997f5007a9298195ae141/w/10c9127921f9ca1b469972cd/e/113bf13ce42853b24dd2b046?renderMode=0&uiState=68b78da3f658bc9915190e5e
Regards
Anirudh
The easiest fix is to change the owner entity of the Mate connector to the spring part. Right now it's owned by a sketch entity.
If you really want to assemble sketches or curves, you can. In the insert part tool in the assembly you need to select sketches. Curves need to be turned into composite parts first in order to add them to an assembly.
Hi,
Thank you for responding. I think it will work now.
I have another question. What is meant by primary context in relation to in-context part design? I got an error while editing a context that it is not primary context. So first make it primary context.
After I made it primary, a Green Dot appeared next to it.
Regards
Anirudh
