Mate connector in part does not show in assembly
anirudh_nehraanirudh_nehra Member Posts: 7 ✭✭
Hi,
Good day to all.
I have a spring part that I created using in context mode. Then I defined an explicit mate connector on it. The problem is that when I try fastened mate in Assembly studio, the mate connector does not show up. It is not easy to assemble springs as the exis can't be defined easiy. I also cannot show reference geometry(such as curves, surfaces etc.) in asssembly mode. Why is this happening?
Screenshot from 2025-09-03 05-34-44.png Screenshot from 2025-09-03 05-33-57.png
Kind Regards
Anirudh Neha
