opMoveCurveBoundary is simply not working right
joshtargo
Member Posts: 495 EDU
I have this code which literally makes a point on the curve i want to trim:
but I get this error:
Unless … the parameter for the point is more than 0.5.
Debug shows the point is where I think it is, at the base of the arrow.
parameter 0.28:
Parameter 0.68:
in addition, helpPoint has absolutely no effect on which side of the curve is removed, nor does flipHeuristics … some of the time.
I am using either one of the endpoints of the curve for helpPoint during testing.
is there any reliable, rational way to simply trim the end off of a curve, which actually behaves the way it should?
Not sure what you've go going in the rest of your code but this https://cad.onshape.com/documents/5584072770c128de9993fa51/w/086ef47d24fc743b535b55de/e/6fad78c66bcee37c2743aad1 is stable. The help point is a bit moot but is included as it does work. The flipper also works…
@GregBrown, thank you. I rewrote that potion from scratch and now it does work. This is for my EZWire that I've been obsessing over for a few weeks now. Almost 1000 lines of code is big for me. Your "definition.whichPoint" is in there. A different approach from RoutingCurve.
