I am trying to use Split Body to duplicate the shape of one part onto another.
scott_schroeder961
Member Posts: 9 EDU
Typically, a plane is used as a cutting tool. Is there no way to use the shape of a part to cut the same shape onto another different shaped part? In my sketch, I have a side view and a front view of the same part. When extruding, neither part looks the same because of the different sketch views. I am trying to use the side view (after extruding) to cut the identical shape onto the side of the extruded front view. How can I do this??
https://cad.onshape.com/documents/bfb23f57986dad4648c64e0f/w/8ea7a42085b269c7b35df264/e/c75619ebcc7f2a9995e901eahttps://cad.onshape.com/documents/bfb23f57986dad4648c64e0f/w/8ea7a42085b0
Access to your document is restricted. It wants to be public.
That link isn't working for me.
You can extrude and intersect.
If you're doing this a lot, there's also this custom feature which automates some of the work:
https://cad.onshape.com/documents/6c4ae7073bbb41d485299a31/w/a75a42c352a4a591769b844c/e/3fa7aee126526b3c0974a8d5
let me try this again…I am trying to copy the shape onto the side of the extruded front view
https://cad.onshape.com/documents/bfb23f57986dad4648c64e0f/w/8ea7a42085b269c7b35df264/e/c75619ebcc7f2a9995e901ea?renderMode=0&uiState=68c0b0b3d84f03d2cb06ea7e
sorry but I cant get the link to work
I would suggest starting here:
https://learn.onshape.com/learn/learning-path/introduction-to-cad
