Multi-Company set up & Part Numbers
digitalcarbondigitalcarbon Member Posts: 96 PRO
I'm on the paid Professional plan-one seat-working as an independent contractor juggling designs for three different startups.
The only reason this is becoming an issue is I need to use the part numbering system in Onshape. So I need to keep my part numbers separate from each company
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,033 PRO
    I don't think it will ever work for your scenario. Best to just keep a spreadsheet for each company with PN/description tracking in it, then manually copy/paste into OS. IMO.
  • digitalcarbondigitalcarbon Member Posts: 96 PRO
    Is that what Enterprise is for?
  • S1monS1mon Member Posts: 3,734 PRO
    Enterprise can help with auto-generating the next number in a sequence and keeping things unique, but handling different schemes for different customers is not built in. Adding a PLM tool like Arena would make that possible.
    https://cad.onshape.com/help/Content/Plans/numbering_schemes.htm
  • robert_johnstonrobert_johnston Member Posts: 62 PRO
    Wish the part numbering wasn't company wide and could do it project by project or a way to break it up. Adding Arena for the ability to do this seems extream.
  • svenolov_nystromsvenolov_nystrom OS Professional Posts: 84 PRO
    Have a look at my discussion Document and part number convention, It can solve your problem
