Hide or delete an imported image
ProApe
Member Posts: 207 ✭✭
Hi,
Is it possible to hide or even delete an imported image when it is needed no more or even bothers you?
Salve
Proape
Yes.
How?
AI search skills unmatched. Been kinda impressed lately with Grok and answers to onshape questions. just basic questions so far.
When you import an image into a sketch, ONLY put the image there, nothing else. Ok to put a construction line bounding box around it for dimensional purposes. That's it. No lines that you will actually use for extruding later. Complete the sketch.
Then create a second sketch. This is the sketch where you will draw your lines to trace and/or eyeball reference the image, that you will later use for extruding/revolving/etc.
Now, you can hide and unhide the image separately from the later geometry.
