Isometric views in drawings
in Drawings
When creating a drawing you are supposed to see two options: no views or 4 views. I am only able to choose the no views option, which allows you to add your own views. For some reason, the "4 views" option is greyed out when I go to create a drawing, regardless of what template I select. When I try and insert views of a part or assembly into a drawing, I cannot add any isometric views. only options are front, back, right etc.
To get the "4 views" option you have to right click a part in a part studio and choose "Create drawing of ... " so Onshape knows which part in the Document you want a drawing of.
Isometric views are created with the Projected view command. You can project off the front view for example to create an isometric.
