Removing an area surrounded by points in an imported dxf
simone_cecchisimone_cecchi Member Posts: 2
Hi guys i'm very new to OnShape. I had a jpeg, exported to dxf, imported in OnShape. Now I'd like to edit the sketch…for example creating the new pink line of the image removing the green part. Is it possible? I can select the points, but it seems i cant move them. The sketcth is derived because importing the dxf directly into the main sketch, it says that was not fully defined. Thank to who will help!
https://cad.onshape.com/documents/106ce70577eb12df12d79f08/w/f7a83c60346a573bfc00ecb4/e/ee957e3462eadedfacae6b69
