Curve Pattern on Spiral with Orientation locked on Circle Center
SkiBoy22SkiBoy22 Member Posts: 10
I want to pattern an object along a curve (ive tried both Helix and Parametric) and lock the orientation on the center of the circle (in my case the Z Axis).
The curve starts at 120mm Radius and ends at 40mm radius
https://cad.onshape.com/documents/00c9db9d02dbafeaa5e0345b/w/500ced153d64ee09c8cacef3/e/7f5494a24f6260ffa34ba8d8?renderMode=0&uiState=68c9b5950dc5a3ffa226f524
Grey: What I get
Red: What I want
  • S1monS1mon Member Posts: 3,790 PRO
    Pattern a sketch feature which is dimensioned by the angle, and coincident with the curve, and re-apply feature.
  • SkiBoy22SkiBoy22 Member Posts: 10
    Im not sure what you mean by dimensioned by the angle?
    I have also made all the refrences other sketches as per the curve pattern tips. It seems to work on the first and last however most of hte instances inbetween are skipped
    Yep. I've tried a bunch of combinations and work arounds, and I'm finding it shockingly difficult to do what you're trying to do.
    I managed to get something that 95% works. It can't handle the last member of the pattern and depending on the count, some pattern instances will flip, but for some values of #c (the count), it works:
    https://cad.onshape.com/documents/f87eec8e04343d46741dbf2c/w/9da5103c5970b339455003ea/e/1c0444aa9daa6801f2423488
  • EvanReeseEvanReese Member, Mentor Posts: 2,696 PRO
    ooh that's a tricky one! I tried a few things and got this working.
    https://cad.onshape.com/documents/07cc9f9029c8433d65138b5c/w/f369bd3fa338a993997075d9/e/c1c7dfefafdb8b6aa3aa9a4a
    Thank you both! Exactly what i needed 😁did not realize you could update a variable! very cool 🤓
    edited September 18
    Yep. It's a weird - but useful - way to do a loop in Onshape. Using a pattern that actually doesn't move anything by itself, except to cycle through features including the increment variable expression.
    I love that technique! I noticed the last instance wasn't always working. I think it's because of a rounding error sometimes making the param go to something like 1.00000001 instead of 1 so I threw it into a min function and it's stable now
    @EvanReese Wow. That kinda makes sense, but definitely a lot more hoops and insider knowledge than should be necessary to make this work.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 481 PRO
    Programmer philosophy? In my mechanical CAD package? It's more likely than you think.
  • MichaelPascoeMichaelPascoe Member Posts: 2,697 PRO
    edited September 18
    Feature pattern appears to a little buggy and unpredictable ever since the pattern update a few updates back.
    You can do this with a single mate connector paired with simplified sketch constraints. But even adding something as simple as a line to centroid seems to break the feature pattern. This is a bug imo since adding a line to the sketch messes with the up-stream mate connector. I've submitted a bug report, we'll see where it goes.
    https://cad.onshape.com/documents/266599a738971262330336fc/w/8b44e6d5e12f9f9c52f2c86b/e/ab346529f8cef3047642b43…
    This is similar to the first approach I tried and didn't like the unstable result I was getting, but I think yours works better via curve pattern. I thought about coding a feature to place mate connectors with X pointed at a chosen vertex, but it felt like overkill haha.
  • Konst_ShKonst_Sh Member Posts: 108 PRO
    edited September 18
    @Konst_Sh funny, I actually tried your Multi Mate Connector in my first approach, but it wasn't pointing the correct direction. I assumed it was because of the feature pattern issues.
    @MichaelPascoe feature pattern is definitely weird, maybe its because it being combined with curve pattern and transform from curve makes it flipped from exact orientation though. But the parameter pattern works as expected in combination with multi mate connector.
    Another option would be to use Path pattern custom feature with orientation option - Normal and tangent - with reference cylinder face around origin
    @Konst_Sh that's fancy! I like that this community is so pumped about Onshape that they keep answering the question after it's been answered because we just can't turn down a CAD challenge.
    @EvanReese
    I enjoy this too, but I'd love to see some Onshape employees chime in. It really seems like we should be able to solve this problem without using custom features, or tricky patterns. Re-apply feature should be more robust.
