Rolled Sheetmetal Part
Hello all, I have a part here that I am trying to create in sheet metal. Its actually a flexible PCB but in Fusion I used the sheet metal tools to model it and get a useable flat pattern from it.
I am in the process of trying to figure out how it can be done in Onshape and I'm just wondering if anyone has any suggestions on a workflow.
I got the main big cyclindrical bend in it using extrude in the sheetmetal tool to creat a rolled part however the leg tabs are proving diffucult.
Thanks for your time, images below.
Paddy
You'll need to make sure there are flat spots where the circular arc transitions into those T junctions. Onshape's sheet metal can't currently support doubly curved geometry or lofted transitions.
