Threaded Holes made with Hole feature called out for "Up to Next" in drawings
I'd like to callout a hole made as shown above where the tapped hole is made through one wall. Typically I'm used to calling this out as "UP TO NEXT" or "THRU 1 WALL" as the depth is a virtual and non-inspectable dimension. Is there any way to edit the hole callout to show as such in the drawing without manually typing out that content? (I'd like it to stay linked directly to the parametric feature).
    This is what I get from the hole call out when using up to next in the part studio.
  • corlandocorlando Member Posts: 2
    I agree, this is a miss in OnShape. A hole that pierces the material wall, even just 1 wall, therefore is not a blind hole = thru-hole. 99.9% of machinists out there would interpret this way. There is a difference between "thru" and "thru-all", again common-language for machinists. I submitted a support req ticket today on this topic + up-voted the comments above. A hole w/ up-to-next termination should = "thru" on the 2D print.
