Two lofts from the same point
peter_pawlakpeter_pawlak Member Posts: 10
I need an "ah-ha" moment. Im making a splitter pipe and want to make two lofts originating from the same extrude face. Basically make the left look like the loft on the right. Seems very simple but i cant select the same extrude face. Am i using the wrong loft parameters in loft one that is causing this?
Screenshot 2025-09-19 at 9.46.39 AM.png Screenshot 2025-09-19 at 9.53.08 AM.png
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,467 PRO
    I think your issue is that you are using "add" for loft1 so the face you lofted from doesn't exit anymore!
    Switch your first loft to "new" and it should solve your problem.
    Or better yet, just mirror your part after creating loft1!
