Improvements to Onshape - September 19th, 2025
2
  • MDesign
    Sooooo then… PlanesPointsCoordinateSystemsDirectionAxes
    OR PPCSDAs for short 😆
    maybe Mate Datums might be more descriptive of what they are.
    A couple of AI suggestions… origin anchor, genesis frame, datum origin, prime locator.
    isn’t a mate and a connector kinda the same thing?
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,163 PRO
    Nah a mate is a pairing, and a connector would be the application that brings the two together. Like Tinder.
  • Chris_D_Mentes_001
    Chris_D_Mentes_001 Member, csevp Posts: 132 PRO
    edited September 2025
    Named Views in Drawings is ducking ground BREAKING! I am so excited to show this off to my boss!!
    Also Assembly mirror is extremely well executed! Bravo development team! Certainly a testiment to your strong foundations on user interface simplicity X
  • billy2
    Mirrored assemblies is mind boggling. With Arena PLM could you really control a design and manufacture a product into a production environment and control the life cycle of a product? I think this the 1st system that could possibly do it. Could you push changes through and update all supply chains, fixtures, product packaging? Basically everything while maintaining a quality system? It'd be fun to see it in action and implemented.
  • billy2
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,123 image
    Originally, Mate connectors were only used for mates, hence the name, but they've come so far since (and more to come). We can't think of a better name so all suggestions are welcome!
  • Ste_Wilson
    Ste_Wilson Member Posts: 687 EDU
    Is this the death knell for the plane old plane?
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    @NeilCooke
    Best name would be Viral Connector🤣
  • MDesign
    I think plane ninja might work. That way plane purists know there is a surgical option. While also reminding that plain planes going the way of the dodo. 😂
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,274 image
    :sigh: this is how rumors get started. We have no plans to get rid of planes in Part Studios.
  • glen_dewsbury
    Would like to see mirrored parts that are derived back to the part studio they started in instead of a new parts studio. Is that possible?
  • jared_fitzclarence
    jared_fitzclarence Member, csevp Posts: 18 PRO
    I think is my favorite update so far in more than 8 years of using OnShape. So many amazing and useful features,
    Mirror implementation looks incredible!
    Configure Sketch Pattern I have been asking for for years!
    Named Views in Drawings - where have you been all my life!
    Can't wait to put these to use, I have models with thousands of parts that would have saved me soooooo many hours with these tools!
  • GWS50
    GWS50 Member Posts: 536 PRO
    Assembly Mirror is saving so much time, I just love it.
    Named Views in drawings is also fantastic…..what an update, thank you Onshape.😀
  • James_P_Miller
    James_P_Miller Member, csevp Posts: 42 PRO
    So happy to have mirror in assemblies, but I'm having an issue with sub-assemblies. When I change their mirror state to "transform", the parts are not in the correct orientation and none of the placement types seem to change anything. Seems like they should just be rotated as an assembly keeping all parts in the same orientation as they are in the sub-assembly. In the example below the cylinder rod tool plate has flipped 180 degrees.
    Am I missing something??
    James P. Miller
    Mechanical Design | Custom Automation | Onshape CAD
    https://millerdesignservices.net
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,062 PRO
    Sometimes coming into the office on Monday is a great thing! Assembly mirror is amazing! And by the looks of it, Onshape has indeed nailed the implementation. Looks to have loads of control in all the right places. 🤩. Hoping for mirrored sheet metal; to be able to include there flat pattern as well. 🤨
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,115 PRO
    Another huge update! Assembly Mirror looks great, can't wait to try it out
    It would be better if the Assembly Mirror maintained Active Sheet-metal
  • martin_kopplow
    Yeah. Assembly mirror is one I've been waiting for. Great!
    But we should also mention folder drag and drop. That's one of the small improvements that make everyday life a little easier. :0) Even though many believe paper drawings are out of fashion, illustrations are not, and the use of named section views will help a lot in assembly instructions and user manuals. I'll certainly be using this.
    This update is a big leap.
  • john_mcclary
    With assembly mirror, still no winners yet:
  • aeromorrison
    aeromorrison Member Posts: 92 PRO
    As someone who designs aircraft that involve lots of complex angles on re-used components with symmetry, I'm super excited about this release. Mirrored assemblies with part re-use has been very tedious thus-far. I'm excited to give it a stress test.
    The named views and drawing usage and BOM flow-through has immediate utility for my team as well. The other updates are all also solid and help to continue rounding out Onshape.
    Well done!
    Sneaky shadow update I noticed, there are more frame profiles included in the Onshape Libraries now like construction lumber:
  • EvanReese
    EvanReese Member, Mentor Posts: 3,091 PRO
    S1mon Member Posts: 4,615 PRO
    I stumbled on the Lumber profiles last Friday, but I think it was before the What's New was posted, so I wasn't sure.
    Looking at the change log, I don't see anything about the Lumber profiles, but I do see this curious item:
    "Improve Bezier feature to be more consistent with the Spline feature."
    Anyone know what that means?
  • MDesign
    Looks like they improved the sketch workflow for those. Interestingly Escape still works for bezier and now also works for Spline. While both right click menu confirm now works. I believe right click confirm bezier just erased all your hard work. one or the other did that and if you escaped one or the other it would erase your work. Very annoying. and very important it got some attention.
  • MDesign
    Having escape confirm splines and beziers seems counter intuitive since escape is used to cancel so many things in all software including other sketch entities in onshape.
  • jelte_steur_info
    Assembly mirrors is huge! Thanks a lot!
    and I'm sure this will be solved soon:
    Wanted to use it today only to find my active sheet metal part wasn't active any more… I guess @Derek_Van_Allen_BD's lefty-flip is still not decommissioned then.
  • svenolov_nystrom
    svenolov_nystrom OS Professional Posts: 88 PRO
    Folders and nested folders is a legacy from The early days of Microsoft window's. It makes no sense in a database driven Onshape.
    A better way to sort documents would be using tags and maybe nested tags like a table of contents.
    always look at the end product of our design work the spare part catalog
    Ex Tesla truck , if you put all assemblies and sub-assemblies in folders it would be a gigantic tree usually 10-12 levels
    Referring to my discussion "name and part number convention" there must be be a smarter way of doing it. No folders
  • GWS50
    I find folders really useful partly to organise into different Clients. I do think that Labels should be visible in the Documents Tab like they used to be a few of updates ago.
