How to copy a sketch by 90 degrees
baumarbaumar OS Professional Posts: 83 PRO
I have a square base structure with walls so they have the same width. Some elements on 2 orthogonal sides are on the same place.
I am looking for a way not to create 1 sketch only for these elements and then turning it by the tangent corner line.
The simplest example would be to sketch a triangle on the Front plane, then a line that is coincident with the right plane and then find a way how to display the triangle from the front plane exactly onto the right plane.
Does anybody knows how to do that?
