A new one for help😊
steen_pedersen968steen_pedersen968 Member Posts: 19 ✭
edited September 2025 in Community Support
i wanna make this pattern on a curved surface
Can anyone help so i Can learn more of this awesome program πŸ˜€
I tryed but nothing close πŸ™ƒ
  • MichaelPascoeMichaelPascoe Member Posts: 2,804 PRO
    There are a few ways you could do this. One way would be to create a iterating feature pattern or variable feature pattern, but these can be overly complex.
    A simpler way would be to use a custom feature like Texture.png Texture. Just add it to your toolbar, then use it to pattern your own texture templates. Here is an example of how to do it in relation to your image:
    https://cad.onshape.com/documents/172bc597d36da1751ec9c3cc/w/9a9b0d105898026566cd42fc/e/0812b63ce3a216f58ce…
    RENDERCAD
    rendercad.aiΒ - Photorealistic product rendering.
    β–šβ–žβ–šβ–žβ–šβ–žβ–šβ–žβ–š
  • steen_pedersen968steen_pedersen968 Member Posts: 19 ✭
    @MichaelPascoe thx a lot gonna look into adding texture to custom feature later today
    works fine playing with it thx
    now trying to put it on a half sphere and a full sphere but cant see whats wrong :)
    can u help @MichaelPascoe
    https://cad.onshape.com/documents/d5c69bc41c49f0f76ea6cb19/w/1d87eaca88cce64292171e67/e/7dc8a5882226d9e2bab81527
    Answer βœ“
    With the current version of Texture there is a bug when trying to do spheres. If you leave a small region open at the top and bottom, it will work. The new version fixes this issue but isn't complete yet.
    Here is an example of how to do it with the current version of Texture:
    https://cad.onshape.com/documents/172bc597d36da1751ec9c3cc/w/9a9b0d105898026566cd42fc/e/50af4d914f…
    RENDERCAD
    thx been playing a lot with it this evening :)
    is it possible to get less dots in the bottom so i looks like the top
    Not currently with the Texture feature.
    You could adjust the width of each of those parts one row at a time like this:
    Also you could use @EvanReese's Attractor Pattern feature.
    RENDERCAD
  • EvanReeseEvanReese Member, Mentor Posts: 2,858 PRO
    It's been on my backlog for a while to update Attractor Pattern to handle periodic surfaces (ones that form a closed loop), but right now it doesn't do great with them. Otherwise this would be a great use-case.
