create a hole
launay_julien
Member Posts: 2 ✭
Hello,
Can't create a hole through the thickness of a sheet metal part!?
I've tried everything. Sketching a circle and then removing material, or using the hole tool from a point sketch. Thanks for your help. There's obviously a bug in OnShape when it comes to sheet metal?
Do you have a solution? Thanks.
Your sincerely.
M. Launay
In general, holes in sheetmetal works just fine. Not sure why you're having an issue.
Share a public document, and you're more likely to get a solution.
