How to hide the frame and name of a sketch in the workspace?
eifelyeti67eifelyeti67 Member Posts: 4
Hello,
I also use onshape to create 2D geometry and this works fine just drawing a sketch and then generate a drawing from it.
What I find annoying is that you cannot hide the rectangular frame and name of the active scetch in the workspace.
When I do such 2D drawings I always hide the main planes (front,...) so they do not disturb me.
It would be helpful to add a small checkbox in the "sketch feature window" (see picture attached) which hides this frame and name.
If there is any other way the hide it please give me a hint.
Regards, Manfred.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    Agreed. Please create or vote on an improvement request in the category on the right ==>
  • huli_boshuli_bos Member Posts: 2
    Any solution for this problem?
    I also get annoyed at not being able to hide this sketch frame.
