Improvements to Onshape - October 29, 2015
 lougallo
                    Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
lougallo
                    Update day! This release has a number of time saving bits that many of you have requested.  Improvements were added to a variety of areas like sketching, mates, document sharing and even feedback!  Let's take a look:
Highlights include:
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
                Highlights include:
- NEW Show mate values - Display mate values for distance between mate connectors on-screen while editing. https://youtu.be/Ta38_Koepq0 https://youtu.be/Ta38_Koepq0
- Plane improvements - Preselection will automatically select appropriate plane types. https://youtu.be/kdp5nPA4H_k https://youtu.be/kdp5nPA4H_k
- NEW Transfer ownership - Documents can be transfered to another user through the Share dialog.  NOTE: The recipient must accept the transfer request for the transfer process to complete.  Acceptance can be done via the Share menu or using the Gear menu on the Documents page.
 How to transfer:
 Accepting a transfer:
- NEW Center point arcs - Arcs can be created using it's center-point, then both endpoints of the arc. https://youtu.be/J0qogx9sKWA https://youtu.be/J0qogx9sKWA
- NEW Share with support from Feedback - New checkbox option in the Feedback tool to share the document with support. https://youtu.be/krFzAu99_xI https://youtu.be/krFzAu99_xI
- NEW Custom drawing templates - Configurable drawing templates upon drawing creation https://youtu.be/ZIF4p5FBjow https://youtu.be/ZIF4p5FBjow
- Plane by Line Angle - Selection of an additional point to set the new plane's "zero" where the angle is measured from.
- Documents that are created by Users who belong to a Company will be owned by the Company by default.
- Documents can now be made public from the Documents page using the Gear menu
- Reorder Drawing sheets in the sheets fly-out
- NEW Optional view label and/or view scale label notes for all views
- New Symbol pulldown menu in Drawing notes
- FREE Plan enforcement - The same FREE plan limits are in place but are now enforced once met (Read-only).  Read more here
Great productivity Onshape!
<my first critic about updates>
"Documents can now be made public from the Documents page using the Gear menu"
- Why do you need straight link to make document public as there is link to share dialog just above?
This is probably convenient for free users who wan't to make a lot of stuff public not to reach limits but have you studied how many pro users need 'quick access' for making documents available to all users?
I thought you try to keep menus as clean as possible for overlapping features and use smart links, this only saves couple of clicks.
</my first critic about updates>
As Lou said, performance is a focus for us, especially right now for drawings, but we're still in the early stages of our current efforts to improve drawings performance. Any improvements you saw were small compared to what we still need to do to get drawings performance up to good levels.
in the mean time I discovered that I was unable to copy out of an annotation text box. Pasting externally generated text did work however.
https://forum.onshape.com/discussion/comment/11751#Comment_11751
projektowanieproduktow.wordpress.com
In the menu where you create new tab..
I don't want to accidentally click 'Make public' -links even though there is confirmation dialog behind..
thanks for listening
Linked[in]
Please keep up the good work, its going to pay off, no doubt about it.
I hope you will soon add an update allows us to create folder in the feature tree, mine get kind of difficult to navigate as they are soooo long.
Great updates!!! Keep them coming!
-Clay
Linked[in]
- in sketches (chain select, most particularly, but also selection filters and other productivity turbo boost features)
- and on solids (currently, the only entity type supporting automatic multiple selection is faces, whereas edges are arguably more deserving of assisted picking, because they present a narrow target for manual methods, requiring pinpoint mouse work)
I think "Select Other" could benefit from some nuanced enhancements.
But much more importantly, I'm hoping the current "Create Selection" RMB tool will be greatly expanded, enhanced and improved to become an object of envy and desire to other MCAD packages and their uses.
(Incidentally, at present, it is NOT greyed out in situations where it is not useful, eg when editing sketches, which is a bit misleading).
I wonder if that single "Create Selection" RMB menu pick, made modal, could become the front end for the entire quiver of streamlining tools (even including making adjustments to selection filters, possibly?).
At its best, the Onshape interface design sets new standards for simplicity hand-in-hand with power and elegance.
The implementations of sketch patterns, the Hole feature, and Mate Connector re-orientation are just a few awesome examples which spring to mind.
It would be insanely great to see that level of excellence achieved in an overarching "Turbo Selection" toolset.
