3D printing models at different scales
graham_lock
Member Posts: 265 PRO
Hi,
Is there a recommended workflow to produce an onshape model which can be exported at different scales?
It might be necessary to tweak some dimensions to suit the scaling to ensure reliable prints.
Does this need to be designed in with dimensions and configurations, or at least partly so, or is there a better way?
Thank you.
_anton
Member, Onshape Employees Posts: 534
If you just need to scale the whole thing, use a configured transform feature. Else, configure individual dimensions.
michael3424
Member Posts: 759 ✭✭✭✭
I expect that virtual all slicing software programs have a built-in scaling feature.
Sounds like a job for configurations.
Thanks guys.
