3D printing models at different scales
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
Is there a recommended workflow to produce an onshape model which can be exported at different scales?
It might be necessary to tweak some dimensions to suit the scaling to ensure reliable prints.
Does this need to be designed in with dimensions and configurations, or at least partly so, or is there a better way?
Thank you.
  • MDesignMDesign Member Posts: 1,346 PRO
    Sounds like a job for configurations.
  • _anton_anton Member, Onshape Employees Posts: 534 image
    If you just need to scale the whole thing, use a configured transform feature. Else, configure individual dimensions.
  • michael3424michael3424 Member Posts: 759 ✭✭✭✭
    I expect that virtual all slicing software programs have a built-in scaling feature.
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thanks guys.
