My audio on learning modules is suddenly gone.. what do I do
bhargavi_pajjuribhargavi_pajjuri Member Posts: 2
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 768 PRO
    This is probably an issue with your browser or your audio output. Also make sure the video isn't muted or the volume turned all the way down. If other audio (YouTube, etc.) works, try a different browser. Also, it might help to provide a link to the specific learning module you are working on.
  • nate_jakenate_jake Member Posts: 7
    This is probably a browser issue, check if there are any updates pending on your browser.
  • michael3424michael3424 Member Posts: 745 ✭✭✭✭
    And check that sound is not turned off in your operating system.
