How do I convert a picture/document into a sketch?
evan_rosenau
Member Posts: 2 ✭
I was wondering when I import a picture how to change it into a sketch
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/e5bdf34d7618a0c8cd011f19
https://cad.onshape.com/documents/24ebbb4af61fa4df9922bdc7/w/4c49a71723e8bf4c8446e57f/e/309093e0c22fd4eaaa5a8371
See help on Insert Image here.
Another tip is to make your original image to the boundaries of the part. Then sizing & positioning it during insert is easier.
I tried many things to use geometry from a logo jpeg, that I converted nicely to svg, and also to dxf, as many comments said it was the only way. InsideOnshape, nzw docment, new sketch, and import tool :
Indeed svg open as an raster image in new tab, import dxf open a new tab - one layer with several splines. Must get ri
I tried the copy/paste, this use tool, and no way to get the splines inside sketch, seems a
