Add condition button not showing on configuration visibility conditions
maxwell_johnson069maxwell_johnson069 Member Posts: 2
Where is the button to add visibility conditions? In the example shown in the help menu it shows a button that says "+ add condition". I do not have this button. I am unable to add any visibility conditions because of this. This is the project in question:
https://cad.onshape.com/documents/a17261f1388944bed7b19437/w/17dcf347174a826eb058698f/e/d5c3407d5d5f09ec9fad3ce4?configuration=height%3D0.028120000000000003%2Bmeter%3Bwidth%3D0.039369999999999995%2Bmeter%3Bwire_diameter%3D0.01%2Bmeter%3Bwire_height_from_base%3D0.0174%2Bmeter%3Bwire_hole%3Dtrue&renderMode=0&rightPanel=configPanel&uiState=68e706ff70c44a081cd825d9
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,467 PRO
    It doesn't support configuration variables yet…
  • _anton_anton Member, Onshape Employees Posts: 501 image
    For context, we don't allow this (yet) because comparing floating-point values is fraught with danger. If you're not careful, you'll get some very mathematically unexpected behavior.
