I am unable to print a drawing from onshape. It either comes out blank or I get an error message
ken_fernalld
Member Posts: 4 ✭
Sometimes the result is blank with no template and no views. Other times I get the message: "Pop-up windows appear to be blocked. Unblock them to enable printing."
How do I print my drawing?
Printing directly from a browser window probably isn't your best option. Try exporting the drawing as a PDF, and print that.
Yes, I was unclear that is what I am trying to do. When I look at the PDF is is blank, no views no title block just blank B size paper.
Don't use the browser print option directly. If your viewing your drawing click the three horizontal lines in the top left (hambuger menu) and print. That should open a new tab with a generated pdf.
On some browsers it may spit out a warning that pop ups have been disabled/blocked.
If so go to your browsers settings, search for pop in the settings and add the onshape website address to the allow box.
