Object floating above the plane.
rob_goring
rob_goring Member Posts: 8
My first time using onshape.
I made a cut (set extrusion to 'remove') and now my design looks like it's floating above the top plane.
Did I do something wrong?
https://cad.onshape.com/documents/71bf8a239481b35cd221691a/w/039b8e3934dc9803ea88e91e/e/ea532cfc96df5e80e638e021?renderMode=0&uiState=68ed54b7c2654d9980b47454
  • jelte_steur_info
    jelte_steur_info Member Posts: 675 PRO
    it may be an optical illusion. if you turn to look at the side you can see it's still flat on top of the top plane:
  • john_rousseau
    john_rousseau Member, Onshape Employees, Developers Posts: 425 image
    The Onshape Learning Center has a ton of good content regardless of your CAD experience: https://learn.onshape.com/
  • jelte_steur_info
  • rob_goring
    I didn't see an edit botton for the post so here's what happened.
    I copied the workspace to try out some changes, and it had dropped to the plane.
    Would still like to know what's going on?
  • rob_goring
    Thank you for the reply. I saved the workspace to make a change, and it dropped down by itself. When I opened the original, it had dropped down also. Weird. Maybe I 'was' seeing things.
