Create Details i.e. "Detail A" - magnified portion of a drawing
colin_dalycolin_daly OS Professional Posts: 37 ✭✭
How can I create a magnified detail within a drawing?
    @colin_daly You could work around this (somewhat laboriously)
    If I badly needed a detail view under current circumstances, I would isolate a copy of that portion of the part in the Part Studio, then create a view of that new part, at a larger scale, in the drawing (on the same sheet).
    One way to do this would be to draw a closed sketch the shape of the desired boundary of the detail view (traditionally a circle), use "Transform" to make a "Copy in Place" of the parent part, then extrude the boundary through the copied part only, selecting the "intersection" option (equivalent to "Flip Side to Cut" in Solidworks)
    Optionally, before using it for the detail view,  you could derive the resulting part into a new Part Studio, and hide it in the original one.
