Help to fix a segment extrusion
Hi Forum,
I taught myself Onshape over several months… I have a rotating seat pivot I designed for a project.
The seat has a tooth that rotates against a with a cap screw stop , the dimension of the tooth permits rotation in either direction.
Sketch 36 is linked to the segment extrusion i made but I am unable to alter the extrusion angles from the sketch which I have adjusted from 80 to 125 degrees (from 25 to 125 degrees). the lines have turned read with errors shown which I am unable to clear.
Is anbody able to come online and show me what the issue is?
https://cad.onshape.com/documents/ae5cf011c97825fcbe4cbcdc/w/11d1faf1ff16e4cdd8fdc881/e/2435af6b8d799ede9c6c51bd
Many thanks David
  • jnewthjnewth Member, OS Professional Posts: 83 PRO
    Sketch 38 is not solved so doesn't produce valid faces for an extrude cut. It's a simple sketch.
    Open the sketch, delete all the line segments.
    Click the inner edge of the cylinder. Click 'u' to use it. This creates a projected sketch entity.
    Click the outer edge. Click 'u'.
    Click the construction lines. Click 'u'.
    With the constructed lines selected, click 'q' or the construction line sketch tool. This will convert the construction lines in to solid lines. The sketch should then solve.
    In Extrude 24, select the sketch area that you want to use as your cutting tool. Because the sketch is solved and the resulting faces are valid, it can cut away the area you want to remove.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 681 ✭✭✭
    Hey David. Did you get this fixed? I see no errors in the sketch upon changing the angular dimensions. - Scotty
  • david_brothers784david_brothers784 Member Posts: 5
    hi Scotty
    Thanks for your reply;
    The sketch is somehow used to associate with the extrusion later on, I thought all i would have to do is alter the sketch angles and the extrusion would update.
    See image below on the back of PART4 i am trying to move the angle around on the extrusion to make the jutting out tooth smaller.
    In the second picture you can see the material i wish to remove.
    Any help greatly appreciated.
    KR David .
    Thank you so much for your help jnewth - much appreciated ;-)
