How to fix weird loft contours
https://cad.onshape.com/documents/dd72674d74a14d5ec22df28b/w/46681a81a8f19803bd996100/e/f50304569d53fb08a295dd69?renderMode=0&uiState=68f45ccedce4e338d8419a38
I tried a slightly different approach and used surface lofting and then enclose to convert to solid
https://cad.onshape.com/documents/8a604851ff5a481b60905997/w/07eeed28b8c799a19d729d68/e/22ea080924bb9ef8f834cc01
I hope this helps
Even though you think you want the nose at a point. It will result better if you have a little curve in your sketches at the points. This is zoomed way in. these magnitude lines on your spline are just .01 mm long with one set to vertical and the other coincident
