I have imported a logo, is there a way to resize the complete logo in Onshape.
dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
edited September 2016 in Community Support
Now I have resize the logo in a program outside onshape, import it again etc.etc.
The proportion of the logo sould stay intact.
Offset is not an option.
Thanks in adva
  • ben_druce929ben_druce929 Member Posts: 5 PRO
    @philip_thomas - Editing DXF's in a sketch in Onshape is a nightmare. The workflow that I'd love to see would be similar to whats in SolidWorks:
    • Import DXF into sketch
    • Group DXF lines into a 'group' or 'block'
    • Move, scale, rotate DXF as necessary
    • Extrude as needed
  • glen_dewsburyglen_dewsbury Member Posts: 1,299 PRO
    On insertion of DXF, the first driving dimension added will set the scale of overall DXF. No further dimensions will have this affect. You'll still need to set location as Philip describes.
  • martin_kopplowmartin_kopplow Member Posts: 1,298 PRO
    That makes an edit after the fact pretty hard to do. I have come to an alternative logo-workflow where I would import it as usual, into it's own part studio, then scale it to something 'round mumber' like say 100 millimeters in width, using the first dimension in the sketch, then fix everything in place. After that, I create surfaces or an extrude from it and apply a scaling factor to the relult by means of the transform feature.I derive that into my design and use projections or booleans, whatever is needed. I can then go back to the transform/scale feature and type a new size at any time without breaking anything, or even make logo size a variable.
  • jelte_steur_infojelte_steur_info Member Posts: 653 PRO
    edited October 2025
    I usually do it this way:
    This way I can import into a new part studio the logo with a proper size in one go.
    I'll transform (MC to MC) it into place afterwards.
    then boolean it off/on or split face etc. Possibly after a 'replace face' with offset face set for curved faces.
    Best to do this in a separate document (perhaps in a logo library folder) so it's easy to find and import into new projects for proper reuse.
