Is there a way to make a gravity effected ball in the assembly or part studio.
William_BarnettWilliam_Barnett Member Posts: 2 EDU
edited November 2020 in Using Onshape
I am trying to make an infinite marble track. My goal is to have a ball roll down a spiral then roll back up.
  • steve_maiettasteve_maietta Member Posts: 54 PRO
    you can make it tangent (tangent mate -although Ive never tried to mate a sphere..?) to your track, and then drag it along.  No "gravity", or interference although they would be nice.
     Don't think animations are a focus for the OnShape team right now.
     Find the animated Rubix Cube thread to see a master at work ...
  • zelig_medsazelig_medsa Member Posts: 2
    What you can try is a slider mate if you are ok with the ball not looking like it is rolling
  • john_lopez363john_lopez363 Member Posts: 138 ✭✭✭
    edited October 20
    @zelig_medsa … make it yes….. animate it, a bit more challenging!
  • martin_kopplowmartin_kopplow Member Posts: 1,065 PRO
    There is an older thread in which I demonstrated a rolling ball:
    https://cad.onshape.com/documents/71fc008d9243a885635708b5/w/0cf8076d68a685a48318f84d/e/d594d6ffb37f162ea7ea0e58
    That was on a stright guide, though, but the mechanism that makes the ball rotate could be adopted.
