Is there a way to make a gravity effected ball in the assembly or part studio.
William_Barnett
Member Posts: 2 EDU
I am trying to make an infinite marble track. My goal is to have a ball roll down a spiral then roll back up.
john_mcclary
Member, Developers Posts: 4,040 PRO
I would be warry of a Tangent sphere to the track.
Instead I would try adding a track guide that the marble follows with a mate connector or some reference point
If you want the marble to appear to rotate, that will be an artistic challenge. For that add your marble to a sub assembly and have a spearate relation making the marble spin in it's assembly, while a mate connector in the assembly is mated to your track
That make sense?
Sorry i can't throw an example your way i'm not by a computer for the next few days5
Don't think animations are a focus for the OnShape team right now.
Find the animated Rubix Cube thread to see a master at work ...
That make sense?
What you can try is a slider mate if you are ok with the ball not looking like it is rolling
@zelig_medsa … make it yes….. animate it, a bit more challenging!
There is an older thread in which I demonstrated a rolling ball:
https://cad.onshape.com/documents/71fc008d9243a885635708b5/w/0cf8076d68a685a48318f84d/e/d594d6ffb37f162ea7ea0e58
That was on a stright guide, though, but the mechanism that makes the ball rotate could be adopted.
