Feature Request - Variable Studio Configuration Type (Specify Which Studio(s) a Part Uses)
AsherAtSignalDesignAsherAtSignalDesign Member Posts: 32
The addition of configurations to variable studios is one of the most needed additions to OnShape. It's great to see, as it addresses one of the single core problems that remains: properly handling encapsulation of part definition and portability of that definition to other parts where definitions have to be coordinated.
One piece seems to be missing: the option to correlate a variable studio configuration with a part studio configuration so that the part studio can utilize whichever variable studio is most appropriate, defined after the fact.
Currently it seems that the only way to achieve this is to manually duplicate all configurations for the variable studio and for the part and then to include the variable studio by specifying all configuration values mapped 1:1. This is an insane amount of wasted effort that should be handled automatically.
An easy way to do this would be to add a configuration type to configure which variable studio would be used. This would effectively include all configurations for each variable studio without cluttering the configurations for the part.
Am I missing something that would make this possible already?
I would put the importance of this at about 1000/10.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,485 PRO
    I'm not sure I 100% understand what you mean but one thing you could do is to use two variable studios:
    • A "master" that has a bunch of different configurations but isn't "inserted" anywhere
    • A "reference" one that is imported into parts and assemblies and whose values are used in features
      • Then you just import the "master" variable studio into the "reference" one and just pick the configuration you import.
      • If you edit the reference one to change it to a different config of the master, all of your document will then use these values
    I realizes as I am typing this that it doesn't give you the option to "switch on the fly" which set of variables are used with a simple "configuration input"…
    And "intermediate" workflow if you had a variable studio with many configuration input and only wanted to create a subset of permutations would be to do the same as above but with the master having all the inputs (i.e. and infinite number of configs if you use input variables), and then have a single configuration list input in the "reference" one with the list of possible valid combinations of input. This would at least reduce the amount of mapping to just one input
  • AsherAtSignalDesignAsherAtSignalDesign Member Posts: 32
    edited October 2025
    That's backwards - it doesn't let you change the configuration of a part by changing the variable configuration.
    The goal here, as I see it, is to be able to make multiple parts from the same instructions using different configurations. Is that not obvious? I'm not sure what could be more important.
    It seems obvious to me that there should be a configuration option to switch out which variables. I'm used to working as a programmer, where these things are a base level assumption. As a result, it's the #1 thing messing up my workflows, which I want to organize in object-oriented, reusable patterns.
    Accordingly, this seems like an enormous oversight - like leaving a gaping hole in a feature that was released. But then, I couldn't understand why encapsulation wasn't priority #1 to start, given that the rest of OnShape design (parts studios, assemblies, etc) is at least nominally based on the idea of encapsulation. It left me very confused to find that actual encapsulation is non-existent. So… I'm hoping it will be fixed.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    It sounds like you have an interesting idea, but I can't quite follow it. You are talking about variable studio configurations, but you are also talking about switching different variable studios for some reason… Could you give a specific example of a design (I'm assuming family of designs, really) you'd want to make and how you'd want the data to be structured?
  • _anton_anton Member, Onshape Employees Posts: 508 image
    I think I hear multiple asks:
    • Flow configs through from the importing tab to the tabs it imports. We're very aware of this need.
    • Configure which variable studio you're importing. I think this is a non-starter: 1. you'd have to have duplicate variable names and configurations, and 2. there's no reason you can't do this by just adding more configs to one variable studio.
    So, like, a part studio defines an interface of what it expects and you can slot in any variable studio you want? I think this is redundant with the fact that the variable studios themselves can be configured.
    edited October 2025
    Yeah I guess he's saying it would be nice to be able to have the whole document use the "currently selected" configuration of a variable studio.
    Right now you can only do this with the workflow I described earlier but it requires editing a variable studio to change the imported configuration rather than setting configuration inputs.
    Basically we need a mode to "push" the variable studio configuration instead of having to pull from all the tabs...
    I was thinking about this some more in the shower…
    What if a variable studio had an option to "push" configuration inputs (the way it pushes the variables) to all part studios/assemblies within a document, and automatically linked them throughout the document structure?
    Eg: add a configuration input to the variable studio and have it show up in the top level assembly so that selecting a specific config from the top level automatically pulls in the same configuration of all children (sub-assemblies down to parts and derived part studios).
    Alternatively, it might make more sense if this was separated from variable studios, maybe we could have a "configuration studio" that could be imported like a variable studio and would automatically link all the configurations down the structure. This could provide a lot of flexibility to manage "sets" of configuration parameters to use across documents in a large project without having to manually re-create and link configuration inputs across everything!
    edited October 2025
    I love the configuration studio concept, and agree that flow-through would be nice, but those are both more involved solutions than what I am proposing.
    I want to be able to define a group of variables that will change based on configuration and that will be portable to different contexts - to multiple parts studios, to assemblies. This is now possible with Variable Studio Configurations.
    Put in terms of Variable Studio prior to configurations: I want to be able to build a Part Studio around a Variable Studio and then be able to swap out the Variable Studio for another equivalent Variable Studio. I appreciate the desire to be able to constrain this so that the replacement will work, but there are a number of places in OnShape where this would be appropriate and is not done— instead, errors are allowed to occur to illuminate that the replacement doesn't work.
    But now that Variable Studios have configurations there is a better option: a new type of configuration that specifies a configurable Variable Studio but instead of configuring it, adds it as a configurable item in the Part Studio configuration. I imagine a similar interface, for example, as the interface when deriving a configurable part. So the box would show the default value (a Variable Studio type) and then clicking on it would permit choosing a different one. Whether this permits selection of any studio or only of other configurations of the specified studio would not matter to me. Either would be fine.
    The key is that a Part Studio can be driven by the configurations after the Parts Studio has created its parts, and that the configurations are themselves portable so that they can be used in other Parts Studios or Assemblies.
    Right now if you create a configurable Variable Studio and then utilize it in a part, you cannot change the Variable Studio Configuration from outside the part's Part Studio (as a Parts Studio configuration permits you to do) unless you manually duplicate each configuration from the Variable Studio into the Parts Studio (not sustainable). This problem corresponds to the desire for "flow-through", but I think that what I'm proposing captures the same advantage with much less work.
    edited October 2025
    I might be missing something but isn't what you are describing already there? Like this:
    I don't understand what you're showing me.
    How does this allow you to change variable configurations at the time when you configure the part?
    No one else sees this as a serious need?
  • S1monS1mon Member Posts: 3,810 PRO
    I think the challenge - at least for me - is that I still don't understand exactly what you're trying to do. We have variable studio configs, and these can be configured. The configuration of a variable studio can drive one or many or all the tabs in a document. Configurations of variable studios can be used to drive other documents.
    What would be most helpful is if you can give a simple concrete example of what problem you are trying to solve. Don't worry about the solution, tell us what you want to do from a real world standpoint. I bet this will either result in someone in the forums having a clever solution or at the very least we might understand what's missing and can help craft an improvement request.
    I had thought the issue to be more straightforward. I will take some time to carefully write up how I understand the problem and report back.
  • euan_dykeseuan_dykes Member Posts: 33 PRO
    I've got the same challenge. Let me try explain the scenario.
    I've got a packaging design that has it's size driven by variables from a parent variable studio. If I change the values in the var studio, the packaging changes in the part studio. In the parent var studio I have configurations. If I change the config in the var studio, it updates the values in the same studio variable table. Then if go to the part studio, the vars are stuck on whatever config the var studio was on when I added it to the part studio. To match the var studio config I need to manually change the config. There's the option to have the default or the last view config.
    If the var studio is like a parent, and the configurations are like moods and the variables are like instructions. Every time the parent's mood changes the poor children are stuck with the instructions the parent gave them when at the time of installing the rules of the house.
    It's also a problem with configs in part studios and the sibling assembly studio, you have to manually update the insert config of the imported parts. Yer sure you can also establish a config table in the assembly and configure the feature as shown in the image example above. Every time you have a new config in the master, the slave needs a manual update too.
    I'm also a bit sad that you can't pass values up to a global object that other's can draw down from and keep the flow. E.g. a critical dimension in a part studio that other part studios can use. You have to create a new overlord to drive the genesis part and all clones that use it. Which would be fine if the above global config would replicate through all local instances.
    The "master" workflow I discuss in the second post in this thread should address pretty much everything you are asking for except for the last bit about passing values back up (but if you added it manually in your master it would be instantly available everywhere.
    Basically you go into your "reference" variable studio and then change which configuration of the "master" is imported and all your assemblies and part studios will update.
    The only thing missing is that you won't be able to control this from an drop down in the assembly…
