Routing curve
ryan_jensonryan_jenson Member Posts: 4
How would I go about sketching two parallel tubes connected to each other to sweep the same path then a have a twist?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 747 ✭✭✭
    Hey Ryan. Perhaps using a helix for the path would satisfy your task. Something like this. - Scotty
  • ryan_jensonryan_jenson Member Posts: 4
    Yes I have seen that example but I would need a non uniform path for the tubes to follow.
    There are 3D spline tools available. An image would be helpful to envision what you are attempting. - Scotty
