find intersection between curve and spline
richard_theodor
Member Posts: 7 ✭
in Drawings
I have made a projected line from a helix on a plane and I want to intersect it with a construction line. How can I get this point?
https://cad.onshape.com/documents/86520da8cf7049766ae210a4/w/d61a04dccfd39b19115f36cb/e/cd1fcdce7d5fd9eaed33ee90
Use a "coincident" relationship?
Maybe the "pierce" command - or even "trim"? Just suggestions, because I'm not 100% sure if I understand your exact needs.
I was able to circumvent my needs by making the curve end, then connect a line to the end point. Not my favorite solution, but it worked :) Thanks for the help!
If you place a sketch point, you should be able to use Coincident on both your construction line and the projected spiral with the point, respectively.
Ramon Yip | glassboard.com
