Exporting Past Drawing Releases
Brian_HensleyBrian_Hensley Member Posts: 3 PRO
After I create a release of a drawing I typically will want to export a PDF. However when I right click on the drawing tab and select ‘Export’ I can only export the current version. It would be help to have drop down menu in this pop up to select previous Releases to export. This saves a user from needing to open the previous release and then export or set up a script as not every drawing needs to have a PDF when it’s released.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 925 PRO
    You can do it pretty easily as seen in this little gifs
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,529 PRO
    edited October 2025
    Or if you already have the drawing open, you can pick "Revision history" (two down from "Export") and then export directly from there.
    EDIT: never mind, that's what's shown at the bottom by @shawn_crocker !
    But there is another way, if you use the "list view" (or "structure view") when browsing the folder it only shows released items so you can export directly from there:
  • Brian_HensleyBrian_Hensley Member Posts: 3 PRO
    Ah, thanks for pointing out the the 'Revision History' option instead of 'Export'.
    I still think that it would make sense to have a button within the 'Export' window that opens the 'Revision History' window but this certainly helps.
