Dynamic simulation and rendering OnShape models
ashraf_sultanashraf_sultan Member Posts: 3
edited November 2015 in Using Onshape
With the release of SimLab Composer 6.1.5
We now have OnShape integration available in each copy of SimLab Composer
Integration page can be found in the following link
Following tutorials show how easy it is to use the new integration plugin:
In addition to Rendering and Simulation, SimLab Composer integration allows the user to export OnShape designs as FBX, OBJ and 3D PDF.
We are looking forward for feedback and feature requests from OnShape users.
    Well, this IS great news.
    "après moi, le déluge" - but hopefully, a good revolution
    Hi Ashraf,
    Is there any live link if model is changed?
  • peter_hallpeter_hall Member Posts: 196 ✭✭✭
    The Simlab website gives no indication on how long you get a trial version for before needing to buy the product. Any idea?
  • ashraf_sultanashraf_sultan Member Posts: 3
    Hello Peter,
    You get a trial for 1 week, then you can send an email to get an extended trial for 1 month
    Currently the transfer is one way, after doing the work you can save the model as a SimLab Composer file, we are working on dynamic linking
