opLoft Tangent Constraints
ry_gbry_gb Member, csevp, pcbaevp Posts: 178 PRO
edited November 2025 in FeatureScript
I'm pretty new to FeatureScript, so I don't quite have all of the syntax down yet. I'm trying to play around with opLoft and am having issues setting both ends to match Tangent. Can one of you more knowledgeable folks tell me what I'm doing wrong?
The start tangent works just fine, but the end tangent fails entirely regardless of whether or not the start tangent is turned on.
Here's the link to the document:
https://cad.onshape.com/documents/4b87997e7164dea20ff0c043/w/3e21b2978617006c0fa53894/e/227c23ce42fa65bfba62e583?renderMode=1&tangentEdgeStyle=1&uiState=690a477d02548ecd385b26e4
Many thanks!
Ramon Yip | glassboard.com
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 375 image
    On line 61 you need to have:
    "profileIndex" : 2,
  • S1monS1mon Member Posts: 3,985 PRO
    Are you able to create the surface with the standard Onshape loft feature? If you can show an example of that working and your feature failing, this might be easier to solve.
    "profileIndex" : 2,
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 178 PRO
    Yeah, I can recreate it with the Onshape loft feature. I just modified the file to include a working version with the regular loft. The purple one is the intended result.
    Thanks @GregBrown! That fixes it. I think I understand why now. Looks like I made a typo in the code and had it as "profileIndex": 0, but I also set it to 1 at some point as well. So as I understand it, it's because there are 3 profile curves, right?
