Improvements to Onshape - October 31st, 2025
mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 198 image
edited November 2025 in New in Onshape
Happy Halloween! This release delivers plenty of treats across CAD, CAM, Render Studio, and Data Management.  Think faster releases, cleaner task workflows, smarter import options, and polished visuals that make your design life a little less scary.
DRAWINGS IMPROVEMENTS
REFER TO CUT LIST DATA ON CALLOUTS
Cut list data can now be referenced directly in callouts for views of individual cut list parts, even if the source Composite frame is not present in the drawing.
https://onshape.wistia.com/medias/2pd5q2uey5
DUPLICATE ROWS OR COLUMNS IN GENERAL TABLES
General tables on drawings now support duplicating rows and columns with current values.
https://onshape.wistia.com/medias/putcuz1624
DATA MANAGEMENT
IMPROVEMENTS TO THE ADD ASSOCIATED DRAWING BUTTON IN RELEASE CANDIDATES
The button to add associated drawings to a release can now pull drawing references from versions, including versions from other documents. Additionally, the button can now pull out of date drawings from both versions and workspaces
https://onshape.wistia.com/medias/j15cw7y3y9
SUPPORT FOR TEAMS AND ALIASES AS TASK ASSIGNEES
Tasks in Onshape Enterprise can now be assigned to Teams or Aliases, not just individuals. This streamlines task workflows and improves collaboration for shared responsibilities.
https://onshape.wistia.com/medias/qce3333dq1
GENERAL IMPROVEMENTS
UPDATED LANDING PAGE EXPERIENCE
The Onshape landing page has been updated for improved consistency and usability, based on user feedback. Expect a cleaner layout and more intuitive access to recent documents and filters.  For Enterprise accounts, the top bar navigation has shifted to the left side of the screen.
https://onshape.wistia.com/medias/292o7m493w
DRAG-AND-DROP IMPORT ON DOCUMENTS PAGE
The Documents landing page now supports drag-and-drop of imported files directly.
https://onshape.wistia.com/medias/3u691bweri
RESIZABLE PROPERTIES DIALOG
The Properties dialog can now be resized, giving you more room to view and edit metadata, especially helpful when working with long property lists or custom attributes.
https://onshape.wistia.com/medias/vn6j4aqxds
UNDO LAST CHANGE TO VIEW ORIENTATION
A new undo action allows you to instantly revert your last view orientation change.
https://onshape.wistia.com/medias/sr7btqy0wq
CAM STUDIO
SUPPORT FOR AIR COOLANT
CAM Studio now includes an Air coolant option in each operation’s posting settings, letting users specify external air cooling during machining for more accurate post-processing and setup documentation.
https://onshape.wistia.com/medias/l4lxdjjyd9
RENDER STUDIO
DRAG-AND-DROP FUNCTION ATTACHMENT FROM RIGHT PANEL
You can now drag and drop functions directly from the right panel library to attach them to appearance properties. This complements the traditional lower-panel workflow and speeds up complex material setup.
https://onshape.wistia.com/medias/xbykigeu1c
MOBILE
REVAMPED TOOLBAR AND FEATURE GROUPING ON iOS
The iOS apps for iPhone and iPad now feature a redesigned toolbar that takes advantage of expanded screen space on modern devices. Feature tools are grouped by type, with recently used tools appearing in the upper right for faster access and improved efficiency.
https://onshape.wistia.com/medias/2fsgm0k86b
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.  Mobile app interface updates occur via the Apple App store or Google Play store and happen in the days following the update.
Regards,
Mike LaFleche   @mlaflecheCAD
    Good stuff! I already set a shortcut for Previous View
  • aeromorrisonaeromorrison Member Posts: 79 PRO
    Solid, quality-of-life improvements in this release.
  • jonathan_hillman285jonathan_hillman285 Member Posts: 3
    nice!
  • Matthew380Matthew380 Member Posts: 50
    I don't see the IOS update on my phone, it is still the same and it doesn't say there is a update for the Onshape App
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 198 image
    @Matthew_Rosete380 the iOS updates happen over the next few days via the Apple App Store. Keep an eye out for the notification there…
    Regards,
  • christopher_dziubachristopher_dziuba Member Posts: 110 ✭✭✭
    Duplicate Table rows/columns gets a tick from me!
  • lorin_zitting750lorin_zitting750 Member Posts: 3 PRO
    There is an update I keep waiting and wanting to see… I work with sheet metal often. On drawings- There needs to be a way to hide some of the automated bend notes. As it is, you can either hide all or show all. The automated bend notes will put multiple callouts on a singular bend line when there is a cutout somewhere on the line. - A bend note is added both sides of the cutout. Some bend lines have many cutouts along the bend. This makes for very messy drawings. I usually end up hiding all bend notes and manually inputing the bend callouts. I have run into this issue many times. I recommend an automated faint construction line that connects across the cutout spaces to show that it is a singular aligned bend. I hope this is an easy update to implement. Thank you!
  • klaus_krämerklaus_krämer Member Posts: 92 ✭✭✭
    "RESIZABLE PROPERTIES DIALOG"
    Great!!!
    Now, please make dimension input fields in sketches also resizable! 😏
  • robert_johnstonrobert_johnston Member Posts: 64 PRO
    I sure hope Sheetmetal Loft is for the Chrismas release at the latest 😉
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 817 PRO
    @robert_johnston If you want it bad enough you can loft sheet metal right now using Surface Flatten and a busted custom featurescript like I did over on the latest Render Battle thread. It's a slightly more laborious workflow but not too bad.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    I stumbled upon the ability to grow the properties menu this morning. Awesome! Didn't see there was an update on Halloween
  • romeograhamromeograham Member, csevp Posts: 748 PRO
    Drag and drop to import files is a really nice improvement.
    Not way fewer clicks, but it feels so natural!
    Is everyone excited for the launch of sheet metal loft today? The day that they'll definitely finally release it?
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 481 PRO
    @Derek_Van_Allen_BD Sheet Metal Loft!?
    I want to believe... 🛸
    @Derek_Van_Allen_BD
    @sebastian_glanzner
    I would pop a champagne 🍾 if happens 🥳
